GarageSale 10.1 Beta 5 Released
Beta 5 version of GarageSale 10.1 is available from this URL for you to evaluate and provide feedback on:
https://downloads.iwascoding.com/downloads/GarageSale_10.1b5.dmg
What’s new in GarageSale 10.1
What’s new in Beta 5
  • Export images command: added option to only export first image of each selected listing, always included image index in file name
What’s new in Beta 4
  • the new ‘Export images’ command works for multiple listings, users can select naming scheme (listing name/SKU) for exported files
What’s new in Beta 3
  • you can configure what fields are exported when exporting orders to CSV, also these configurations can be saved and restored
What’s new in Beta 2
  • editing of ‘Condition Description’ for multiple listings at once works in more cases
  • fixed size/location restoration of ‘Send Offer to Watchers’ window
What’s new in Beta 1
  • new smart group rules for domestic and international shipping services
  • field configurations in the ‘CSV Import Panel’ can now be saved and restored
  • added ‘Condition’ column to Listing overview table
  • listing and inventory item titles can be edited in image overview mode
  • grouped sorting commands in Listing outline view
  • added ‘Export Images…’ command to image context menus and ‘Listing/Images’ menu
  • when dragging images from Editor mode, resulting file names start with listing title
  • added ‘Private Listing’ as an option to the field list in Revise Item panel
  • Listing section: added ‘High Bidder ID’ column to overview table
  • Orders section: ordered items can be sorted by name, SKU, and price from items table context menu
  • Orders section: added ‘Buyer Account’ column to overview table
  • Orders section: improved performance when selecting large number of orders
  • fixed hang when Spelling panel was wrapping around in Preview web view
  • fixed Inspector show/hide bug on macOS 27.2 Beta
  • some synchronization errors are no longer blocking GarageSale
Kristian, Paul, and Ilja
I get different results for file names and file modified dates and file created dates when I drag-and-drop images files to the Desktop verses when I Export Images…
Is this the intended behavior??
Not intended, but I guess that’s what you end up with if you only do the minimum work. :grimacing:
  • Export images: GarageSale has full control and is in charge of copying the files to the destination folder
  • Dragging images: GarageSale creates drag objects backed by files, the application that receives the drag (e.g. Finder) is responsible for creating files at the correct destination from the drag.
Which behavior do you prefer?
“Which behavior do you prefer?”
I think the Export images behavior makes more sense…
Filenames with image-index position number, and original file dates.
