(The built-in update mechanism in previous versions of GarageSale contains a bug. When run under OS X 10.10 Yosemite, GarageSale versions prior to 6.9.1 will not recognize newer updates. To cure this problem, please download GarageSale 6.9.3 from URL above.)
What’s new in GarageSale 6.9.3:
fixed a bug that prevented variation listings from being listed as Good-Til-Canceled (GTC) listings
when importing inventory items from CSV files, there is now an option to update existing inventory objects
updated shipping services names for eBay UK to match names on eBay’s website
System Requirements:
GarageSale 6.9.3 requires OS X 10.9 or later.
Pricing:
GarageSale 6.9.3 is free update for GarageSale 6 users.
Ilja on behalf of the whole GS team
Hi, My version 6.9 installed direct from the App Store. Can i use this version? i did try it but it asked for user info i don’t have (as my purchase was from the App store) where do i find this?
Can you please send an e-mail to the GarageSale support team at garagesale@iwascoding.com and attach any Crash report files from GarageSale located in your user’s home directory Library/Logs/DiagnosticReports.
If you don’t see a folder called Library in your home folder, you have to “unhide” it using the View > View Options command.
