The second beta version of GarageSale 7.0.11 is available for you to download from the URL below, or the built-in updater if you are running an older beta version.
https://downloads.iwascoding.com/downloads/GarageSale_7.0.11b2.dmg
- re-listed listings now appear immediately in the outline view, without waiting for additional details from eBay. This fixes a problem where the listings never appeared in the outline view if the additional details were never received.
- added “whole words only” search option that only shows search results containing the search strings as a whole word
- added “Ship with Endicia…” command to the context menu of the outline view in the Orders section
- business profile names for shipping, returns, and payment can be specified when importing listings from XML files
- bug fixes
What’s new in GarageSale 7.0.11
- adds support for an upcoming change to eBay’s image upload system
- GarageSale will uploaded specified product code to eBay if you selected a product from eBay’s catalog
- added ‘Don’t show again’ checkbox to panel that is shown when trying to start already started listing
- fixed a crash when trying to add an image to Editor mode via drag & drop from another app under macOS 10.12
- added experimental support for eBay Plus on eBay Germany
- improved performance when downloading new PayPal transactions
- improved performance when checking for non-HTTPS image or image links while editing listing description
