GarageSale 7.0.13 (final version) is available for you to download from the URL below, or the built-in updater.
https://downloads.iwascoding.com/downloads/GarageSale_7.0.13.dmg
- duration and handling time settings can be applied via ‘Copy/Paste listing components’ command
What’s new in GarageSale 7.0.13
- no longer embeds low-resolution images hosted on eBay into your listing descriptions
- when receiving errors when listing items on eBay, errors received during verification phase a no longer shown
- image context menu in inventory section now shows image size
- improved shipping settings import when importing listings with “Import from My eBay” command
- improved retry strategy when uploading to EPS fails
- added context menu item in HTML editor mode to turn off auto-complete for tags
- you can drag item from the “Import from eBay” panel to the listing ID field in the live inspector to link listings in GarageSale with listings on eBay
- fixed crash when processing orders originating the Canada FR site (which GS doesn’t support yet)
- removed “create clickable link” checkbox from Create Link panel
