The third beta version of GarageSale 7.0.14 is available for you to download from the URL below, or from the built-in updater:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.14b3.dmg
- further improvements to the ‘Reveal Original’ command
- prevents an eBay warning about ‘eBay Plus’ from showing up when listing on eBay Germany
- added a ‘Reset Overview Sort Order’ command which restores outline view sort order in overview table view
What’s new in GarageSale 7.0.14
- adds graphical indicators in listing editor mode for gallery images and images with captions
- fixed an issue where the ‘Exclude Locations’ list in the shipping panel remained empty
- fixed an issue where incomplete category data was downloaded from eBay when no or an invalid eBay token was available
- the list of fields selected to be searched from the search popup menu is saved
- when manually re-listing items, the re-listed listing is now selected instead of the original listing
- re-listed listing are now inserted into the hierarchy at the correct position
- fixed a possible crash during re-listing, when the re-listed became part of a smart group
- improved ‘Reveal Original’ command for smart groups items
- fixed a possible crash during re-list when no account token is present
- multi-selection overview updates after smart group rules are changed
- increased width of number input field in smart group editor
