The final version of GarageSale 7.0.14 is available for you to download from the URL below, or from the built-in updater:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.14.dmg
What’s new since the last beta version
- fixes a bug where changes to the item specifics weren’t saved when the specifics popover was closed by clicking on another listing
- text blocks are inserted at the current insertion mark location when using editor mode to edit HTML or Markdown description
- listing description in editor mode gets refreshed when changed via AppleScript
What’s new in GarageSale 7.0.14
- adds graphical indicators in listing editor mode for gallery images and images with captions
- fixed an issue where the ‘Exclude Locations’ list in the shipping panel remained empty
- fixed an issue where incomplete category data was downloaded from eBay when no or an invalid eBay token was available
- the list of fields selected to be searched from the search popup menu is saved
- when manually re-listing items, the re-listed listing is now selected instead of the original listing
- re-listed listing are now inserted into the hierarchy at the correct position
- fixed a possible crash during re-listing, when the re-listed became part of a smart group
- improved ‘Reveal Original’ command for smart groups items
- fixed a possible crash during re-list when no account token is present
- multi-selection overview updates after smart group rules are changed
- increased width of number input field in smart group editor
- prevents an eBay warning about ‘eBay Plus’ from showing up when listing on eBay Germany
- added a ‘Reset Overview Sort Order’ command which restores outline view sort order in overview table view
- inventory CSV import now accepts semicolons as column separators
- added an AppleScript example demonstrating the usage of the ‘duplicate listing’ command
- unified spelling of several menu commands
- menu of external image editors is alphabetically sorted
- fixed a bug that caused smart groups with rules for certain amounts to show wrong results
- when moving original listings during a relist to a new folder, that folder doesn’t get automatically expanded anymore
- when switching to search mode and the original selection cannot be restored, the first found item gets selected
- the ‘show only exact matches only’ search option is now saved to preferences
- content area correctly reflects current selection after an drag & drop operation in outline view
- selection is retained when switching between table and image overview
- when activating image overview, it shows correct content, when outline view selection was previously changed while in table overview
- the ‘Cancel’ button in the 'Wait on Quit" panel now works correctly
- best offer details are available as separate field for revising listings on eBay
- amount columns in table overview now correctly update when amounts change
- fix a crash when changing certain attributes through popups for a listing selected in a smart group
- fixed a display issue with sales tax inspector
- improved detection of “feedback received” flag
- the ‘quantity sold’ property for orders is now available exposed through AppleScript
- when importing listings from an XML file, images from an inventory item linked through an SKU are no correctly added to the imported listing
- shipping destinations for international shipping services can be set via AppleScript
- disabled accounts are no longer available for starting listings are creating scheduler events
