ilja
July 5, 2019, 3:59pm
#1
GarageSale 7.0.18 is available for you to download from the URL below, or the built-in update mechanism:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.18.dmg
What’s new in GarageSale 7.0.18
fixed missing translations in non-English variants
GarageSale 7 requires OS X 10.10 or later
My GS still crashes on opening with this application 7.0.18. I have downloaded 3 new applications in 3 weeks and still it won’t work. I sent you the crash messages which took up 3 emails and after that I couldn’t send anything more from that thread. 3 is the limit, so I’ll try to get through to someone from another thread!
ilja
July 9, 2019, 8:23am
#3
I looked at the crash log you posted here:
Process: GarageSale [4930]
Path: /Applications/GarageSale.app/Contents/MacOS/GarageSale
Identifier: com.iwascoding.garagesale7
Version: 7.0.17b3 (852)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: GarageSale [4930]
User ID: 503
Date/Time: 2019-06-26 12:12:16.684 -0500
OS Version: Mac OS X 10.11.6 (15G22010)
Report Version: 11
Anonymous UUID…
Unfortunately, there is not much information in it to act on. What happens if you start GarageSale while your Mac is temporarly disconnected from the internet?
It still crashed in all 3 versions 7.0.16, 7.0.17, and 7.0.18 on start up with out the internet. I have been down now going on 4 months, this is financially ruining me. Last year was hurricane Micheal, and I was down 3 months without internet. We are still trying to get our house fixed which requires moving my inventory and household items. I cannot keep going on like this it is financially killing us!
ilja
July 9, 2019, 7:30pm
#5
Can you post the crash log again? The last crash happened in response to some kind of network operation finishing. It would be interesting to see why it sill crashes when no network is present.
Also, have you tried GarageSale 8?
8 require a higher operating system then my computer will except. I can only give you some of the cash log. it is too long. So I will start from when I rebooted the computer and it failed to open GS.
7/9/19 3:15:26.277 PM com.apple.xpc.launchd[1]: (com.hp.help.tocgenerator) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
7/9/19 3:15:36.350 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:15:36.365 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:15:36.369 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:15:36.390 PM appleeventsd[53]: SecTaskLoadEntitlements failed error=22
7/9/19 3:15:36.409 PM sharedfilelistd[311]: SecTaskLoadEntitlements failed error=22
7/9/19 3:15:36.410 PM TOCGenerator[1915]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.11.6. This is not a bug in Gestalt – it is a documented limitation. Use NSProcessInfo’s operatingSystemVersion property to get correct system version number.
Call location:
7/9/19 3:15:36.410 PM TOCGenerator[1915]: 0 CarbonCore 0x900e4e3d ___Gestalt_SystemVersion_block_invoke + 135
7/9/19 3:15:36.410 PM TOCGenerator[1915]: 1 libdispatch.dylib 0x9836983f _dispatch_client_callout + 50
7/9/19 3:15:36.410 PM TOCGenerator[1915]: 2 libdispatch.dylib 0x9836971b dispatch_once_f + 78
7/9/19 3:15:36.410 PM TOCGenerator[1915]: 3 libdispatch.dylib 0x9836afa5 dispatch_once + 31
7/9/19 3:15:36.410 PM TOCGenerator[1915]: 4 CarbonCore 0x900608e1 _Gestalt_SystemVersion + 1047
7/9/19 3:15:36.410 PM TOCGenerator[1915]: 5 CarbonCore 0x9006008a Gestalt + 154
7/9/19 3:15:36.411 PM TOCGenerator[1915]: 6 TOCGenerator 0x000023da -[AppDelegate applicationDidFinishLaunching:] + 28
7/9/19 3:15:37.075 PM com.apple.xpc.launchd[1]: (com.hp.help.tocgenerator) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
7/9/19 3:15:47.146 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:15:47.162 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:15:47.165 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:15:47.186 PM appleeventsd[53]: SecTaskLoadEntitlements failed error=22
7/9/19 3:15:47.205 PM sharedfilelistd[311]: SecTaskLoadEntitlements failed error=22
7/9/19 3:15:47.206 PM TOCGenerator[1918]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.11.6. This is not a bug in Gestalt – it is a documented limitation. Use NSProcessInfo’s operatingSystemVersion property to get correct system version number.
Call location:
7/9/19 3:15:47.206 PM TOCGenerator[1918]: 0 CarbonCore 0x900e4e3d ___Gestalt_SystemVersion_block_invoke + 135
7/9/19 3:15:47.206 PM TOCGenerator[1918]: 1 libdispatch.dylib 0x9836983f _dispatch_client_callout + 50
7/9/19 3:15:47.206 PM TOCGenerator[1918]: 2 libdispatch.dylib 0x9836971b dispatch_once_f + 78
7/9/19 3:15:47.206 PM TOCGenerator[1918]: 3 libdispatch.dylib 0x9836afa5 dispatch_once + 31
7/9/19 3:15:47.206 PM TOCGenerator[1918]: 4 CarbonCore 0x900608e1 _Gestalt_SystemVersion + 1047
7/9/19 3:15:47.206 PM TOCGenerator[1918]: 5 CarbonCore 0x9006008a Gestalt + 154
7/9/19 3:15:47.206 PM TOCGenerator[1918]: 6 TOCGenerator 0x000023da -[AppDelegate applicationDidFinishLaunching:] + 28
7/9/19 3:15:47.412 PM com.apple.xpc.launchd[1]: (com.hp.help.tocgenerator) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
7/9/19 3:15:57.486 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:15:57.501 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:15:57.504 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:15:57.524 PM appleeventsd[53]: SecTaskLoadEntitlements failed error=22
7/9/19 3:15:57.545 PM sharedfilelistd[311]: SecTaskLoadEntitlements failed error=22
7/9/19 3:15:57.546 PM TOCGenerator[1920]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.11.6. This is not a bug in Gestalt – it is a documented limitation. Use NSProcessInfo’s operatingSystemVersion property to get correct system version number.
Call location:
7/9/19 3:15:57.546 PM TOCGenerator[1920]: 0 CarbonCore 0x900e4e3d ___Gestalt_SystemVersion_block_invoke + 135
7/9/19 3:15:57.546 PM TOCGenerator[1920]: 1 libdispatch.dylib 0x9836983f _dispatch_client_callout + 50
7/9/19 3:15:57.546 PM TOCGenerator[1920]: 2 libdispatch.dylib 0x9836971b dispatch_once_f + 78
7/9/19 3:15:57.546 PM TOCGenerator[1920]: 3 libdispatch.dylib 0x9836afa5 dispatch_once + 31
7/9/19 3:15:57.546 PM TOCGenerator[1920]: 4 CarbonCore 0x900608e1 _Gestalt_SystemVersion + 1047
7/9/19 3:15:57.546 PM TOCGenerator[1920]: 5 CarbonCore 0x9006008a Gestalt + 154
7/9/19 3:15:57.546 PM TOCGenerator[1920]: 6 TOCGenerator 0x000023da -[AppDelegate applicationDidFinishLaunching:] + 28
7/9/19 3:15:57.754 PM com.apple.xpc.launchd[1]: (com.hp.help.tocgenerator) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
7/9/19 3:16:07.831 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:07.845 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:07.848 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:07.868 PM appleeventsd[53]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:07.888 PM sharedfilelistd[311]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:07.888 PM TOCGenerator[1922]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.11.6. This is not a bug in Gestalt – it is a documented limitation. Use NSProcessInfo’s operatingSystemVersion property to get correct system version number.
Call location:
7/9/19 3:16:07.888 PM TOCGenerator[1922]: 0 CarbonCore 0x900e4e3d ___Gestalt_SystemVersion_block_invoke + 135
7/9/19 3:16:07.888 PM TOCGenerator[1922]: 1 libdispatch.dylib 0x9836983f _dispatch_client_callout + 50
7/9/19 3:16:07.888 PM TOCGenerator[1922]: 2 libdispatch.dylib 0x9836971b dispatch_once_f + 78
7/9/19 3:16:07.888 PM TOCGenerator[1922]: 3 libdispatch.dylib 0x9836afa5 dispatch_once + 31
7/9/19 3:16:07.888 PM TOCGenerator[1922]: 4 CarbonCore 0x900608e1 _Gestalt_SystemVersion + 1047
7/9/19 3:16:07.888 PM TOCGenerator[1922]: 5 CarbonCore 0x9006008a Gestalt + 154
7/9/19 3:16:07.888 PM TOCGenerator[1922]: 6 TOCGenerator 0x000023da -[AppDelegate applicationDidFinishLaunching:] + 28
7/9/19 3:16:08.039 PM com.apple.xpc.launchd[1]: (com.hp.help.tocgenerator) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
7/9/19 3:16:18.111 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:18.125 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:18.129 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:18.150 PM appleeventsd[53]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:18.169 PM sharedfilelistd[311]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:18.170 PM TOCGenerator[1924]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.11.6. This is not a bug in Gestalt – it is a documented limitation. Use NSProcessInfo’s operatingSystemVersion property to get correct system version number.
Call location:
7/9/19 3:16:18.170 PM TOCGenerator[1924]: 0 CarbonCore 0x900e4e3d ___Gestalt_SystemVersion_block_invoke + 135
7/9/19 3:16:18.170 PM TOCGenerator[1924]: 1 libdispatch.dylib 0x9836983f _dispatch_client_callout + 50
7/9/19 3:16:18.170 PM TOCGenerator[1924]: 2 libdispatch.dylib 0x9836971b dispatch_once_f + 78
7/9/19 3:16:18.170 PM TOCGenerator[1924]: 3 libdispatch.dylib 0x9836afa5 dispatch_once + 31
7/9/19 3:16:18.170 PM TOCGenerator[1924]: 4 CarbonCore 0x900608e1 _Gestalt_SystemVersion + 1047
7/9/19 3:16:18.170 PM TOCGenerator[1924]: 5 CarbonCore 0x9006008a Gestalt + 154
7/9/19 3:16:18.170 PM TOCGenerator[1924]: 6 TOCGenerator 0x000023da -[AppDelegate applicationDidFinishLaunching:] + 28
7/9/19 3:16:18.319 PM com.apple.xpc.launchd[1]: (com.hp.help.tocgenerator) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
7/9/19 3:16:28.394 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:28.410 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:28.412 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:28.433 PM appleeventsd[53]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:28.453 PM sharedfilelistd[311]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:28.454 PM TOCGenerator[1926]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.11.6. This is not a bug in Gestalt – it is a documented limitation. Use NSProcessInfo’s operatingSystemVersion property to get correct system version number.
Call location:
7/9/19 3:16:28.454 PM TOCGenerator[1926]: 0 CarbonCore 0x900e4e3d ___Gestalt_SystemVersion_block_invoke + 135
7/9/19 3:16:28.454 PM TOCGenerator[1926]: 1 libdispatch.dylib 0x9836983f _dispatch_client_callout + 50
7/9/19 3:16:28.454 PM TOCGenerator[1926]: 2 libdispatch.dylib 0x9836971b dispatch_once_f + 78
7/9/19 3:16:28.454 PM TOCGenerator[1926]: 3 libdispatch.dylib 0x9836afa5 dispatch_once + 31
7/9/19 3:16:28.454 PM TOCGenerator[1926]: 4 CarbonCore 0x900608e1 _Gestalt_SystemVersion + 1047
7/9/19 3:16:28.454 PM TOCGenerator[1926]: 5 CarbonCore 0x9006008a Gestalt + 154
7/9/19 3:16:28.454 PM TOCGenerator[1926]: 6 TOCGenerator 0x000023da -[AppDelegate applicationDidFinishLaunching:] + 28
7/9/19 3:16:29.372 PM com.apple.xpc.launchd[1]: (com.hp.help.tocgenerator) Service only ran for 1 seconds. Pushing respawn out by 9 seconds.
7/9/19 3:16:38.445 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:38.460 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:38.463 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:38.483 PM appleeventsd[53]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:38.504 PM sharedfilelistd[311]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:38.505 PM TOCGenerator[1928]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.11.6. This is not a bug in Gestalt – it is a documented limitation. Use NSProcessInfo’s operatingSystemVersion property to get correct system version number.
Call location:
7/9/19 3:16:38.505 PM TOCGenerator[1928]: 0 CarbonCore 0x900e4e3d ___Gestalt_SystemVersion_block_invoke + 135
7/9/19 3:16:38.505 PM TOCGenerator[1928]: 1 libdispatch.dylib 0x9836983f _dispatch_client_callout + 50
7/9/19 3:16:38.505 PM TOCGenerator[1928]: 2 libdispatch.dylib 0x9836971b dispatch_once_f + 78
7/9/19 3:16:38.505 PM TOCGenerator[1928]: 3 libdispatch.dylib 0x9836afa5 dispatch_once + 31
7/9/19 3:16:38.505 PM TOCGenerator[1928]: 4 CarbonCore 0x900608e1 _Gestalt_SystemVersion + 1047
7/9/19 3:16:38.505 PM TOCGenerator[1928]: 5 CarbonCore 0x9006008a Gestalt + 154
7/9/19 3:16:38.505 PM TOCGenerator[1928]: 6 TOCGenerator 0x000023da -[AppDelegate applicationDidFinishLaunching:] + 28
7/9/19 3:16:38.659 PM com.apple.xpc.launchd[1]: (com.hp.help.tocgenerator) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
7/9/19 3:16:48.729 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:48.744 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:48.747 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:48.768 PM appleeventsd[53]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:48.788 PM sharedfilelistd[311]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:48.789 PM TOCGenerator[1930]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.11.6. This is not a bug in Gestalt – it is a documented limitation. Use NSProcessInfo’s operatingSystemVersion property to get correct system version number.
Call location:
7/9/19 3:16:48.789 PM TOCGenerator[1930]: 0 CarbonCore 0x900e4e3d ___Gestalt_SystemVersion_block_invoke + 135
7/9/19 3:16:48.789 PM TOCGenerator[1930]: 1 libdispatch.dylib 0x9836983f _dispatch_client_callout + 50
7/9/19 3:16:48.789 PM TOCGenerator[1930]: 2 libdispatch.dylib 0x9836971b dispatch_once_f + 78
7/9/19 3:16:48.790 PM TOCGenerator[1930]: 3 libdispatch.dylib 0x9836afa5 dispatch_once + 31
7/9/19 3:16:48.790 PM TOCGenerator[1930]: 4 CarbonCore 0x900608e1 _Gestalt_SystemVersion + 1047
7/9/19 3:16:48.790 PM TOCGenerator[1930]: 5 CarbonCore 0x9006008a Gestalt + 154
7/9/19 3:16:48.790 PM TOCGenerator[1930]: 6 TOCGenerator 0x000023da -[AppDelegate applicationDidFinishLaunching:] + 28
7/9/19 3:16:48.912 PM com.apple.xpc.launchd[1]: (com.hp.help.tocgenerator) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
7/9/19 3:16:58.983 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:58.999 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:59.002 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:59.023 PM appleeventsd[53]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:59.043 PM sharedfilelistd[311]: SecTaskLoadEntitlements failed error=22
7/9/19 3:16:59.043 PM TOCGenerator[1932]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.11.6. This is not a bug in Gestalt – it is a documented limitation. Use NSProcessInfo’s operatingSystemVersion property to get correct system version number.
Call location:
7/9/19 3:16:59.044 PM TOCGenerator[1932]: 0 CarbonCore 0x900e4e3d ___Gestalt_SystemVersion_block_invoke + 135
7/9/19 3:16:59.044 PM TOCGenerator[1932]: 1 libdispatch.dylib 0x9836983f _dispatch_client_callout + 50
7/9/19 3:16:59.044 PM TOCGenerator[1932]: 2 libdispatch.dylib 0x9836971b dispatch_once_f + 78
7/9/19 3:16:59.044 PM TOCGenerator[1932]: 3 libdispatch.dylib 0x9836afa5 dispatch_once + 31
7/9/19 3:16:59.044 PM TOCGenerator[1932]: 4 CarbonCore 0x900608e1 _Gestalt_SystemVersion + 1047
7/9/19 3:16:59.044 PM TOCGenerator[1932]: 5 CarbonCore 0x9006008a Gestalt + 154
7/9/19 3:16:59.044 PM TOCGenerator[1932]: 6 TOCGenerator 0x000023da -[AppDelegate applicationDidFinishLaunching:] + 28
7/9/19 3:16:59.499 PM com.apple.xpc.launchd[1]: (com.hp.help.tocgenerator) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
7/9/19 3:17:09.570 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:09.585 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:09.588 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:09.608 PM appleeventsd[53]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:09.627 PM sharedfilelistd[311]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:09.627 PM TOCGenerator[1934]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.11.6. This is not a bug in Gestalt – it is a documented limitation. Use NSProcessInfo’s operatingSystemVersion property to get correct system version number.
Call location:
7/9/19 3:17:09.628 PM TOCGenerator[1934]: 0 CarbonCore 0x900e4e3d ___Gestalt_SystemVersion_block_invoke + 135
7/9/19 3:17:09.628 PM TOCGenerator[1934]: 1 libdispatch.dylib 0x9836983f _dispatch_client_callout + 50
7/9/19 3:17:09.628 PM TOCGenerator[1934]: 2 libdispatch.dylib 0x9836971b dispatch_once_f + 78
7/9/19 3:17:09.628 PM TOCGenerator[1934]: 3 libdispatch.dylib 0x9836afa5 dispatch_once + 31
7/9/19 3:17:09.628 PM TOCGenerator[1934]: 4 CarbonCore 0x900608e1 _Gestalt_SystemVersion + 1047
7/9/19 3:17:09.628 PM TOCGenerator[1934]: 5 CarbonCore 0x9006008a Gestalt + 154
7/9/19 3:17:09.628 PM TOCGenerator[1934]: 6 TOCGenerator 0x000023da -[AppDelegate applicationDidFinishLaunching:] + 28
7/9/19 3:17:09.753 PM com.apple.xpc.launchd[1]: (com.hp.help.tocgenerator) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
7/9/19 3:17:19.822 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:19.837 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:19.840 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:19.860 PM appleeventsd[53]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:19.879 PM sharedfilelistd[311]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:19.880 PM TOCGenerator[1936]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.11.6. This is not a bug in Gestalt – it is a documented limitation. Use NSProcessInfo’s operatingSystemVersion property to get correct system version number.
Call location:
7/9/19 3:17:19.880 PM TOCGenerator[1936]: 0 CarbonCore 0x900e4e3d ___Gestalt_SystemVersion_block_invoke + 135
7/9/19 3:17:19.880 PM TOCGenerator[1936]: 1 libdispatch.dylib 0x9836983f _dispatch_client_callout + 50
7/9/19 3:17:19.880 PM TOCGenerator[1936]: 2 libdispatch.dylib 0x9836971b dispatch_once_f + 78
7/9/19 3:17:19.880 PM TOCGenerator[1936]: 3 libdispatch.dylib 0x9836afa5 dispatch_once + 31
7/9/19 3:17:19.880 PM TOCGenerator[1936]: 4 CarbonCore 0x900608e1 _Gestalt_SystemVersion + 1047
7/9/19 3:17:19.880 PM TOCGenerator[1936]: 5 CarbonCore 0x9006008a Gestalt + 154
7/9/19 3:17:19.880 PM TOCGenerator[1936]: 6 TOCGenerator 0x000023da -[AppDelegate applicationDidFinishLaunching:] + 28
7/9/19 3:17:20.340 PM com.apple.xpc.launchd[1]: (com.hp.help.tocgenerator) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
7/9/19 3:17:30.409 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:30.425 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:30.428 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:30.450 PM appleeventsd[53]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:30.470 PM sharedfilelistd[311]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:30.470 PM TOCGenerator[1938]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.11.6. This is not a bug in Gestalt – it is a documented limitation. Use NSProcessInfo’s operatingSystemVersion property to get correct system version number.
Call location:
7/9/19 3:17:30.470 PM TOCGenerator[1938]: 0 CarbonCore 0x900e4e3d ___Gestalt_SystemVersion_block_invoke + 135
7/9/19 3:17:30.470 PM TOCGenerator[1938]: 1 libdispatch.dylib 0x9836983f _dispatch_client_callout + 50
7/9/19 3:17:30.470 PM TOCGenerator[1938]: 2 libdispatch.dylib 0x9836971b dispatch_once_f + 78
7/9/19 3:17:30.470 PM TOCGenerator[1938]: 3 libdispatch.dylib 0x9836afa5 dispatch_once + 31
7/9/19 3:17:30.471 PM TOCGenerator[1938]: 4 CarbonCore 0x900608e1 _Gestalt_SystemVersion + 1047
7/9/19 3:17:30.471 PM TOCGenerator[1938]: 5 CarbonCore 0x9006008a Gestalt + 154
7/9/19 3:17:30.471 PM TOCGenerator[1938]: 6 TOCGenerator 0x000023da -[AppDelegate applicationDidFinishLaunching:] + 28
7/9/19 3:17:31.045 PM com.apple.xpc.launchd[1]: (com.hp.help.tocgenerator) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
7/9/19 3:17:32.012 PM Safari[810]: tcp_connection_tls_session_error_callback_imp 27 __tcp_connection_tls_session_callback_write_block_invoke.434 error 22
7/9/19 3:17:41.112 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:41.127 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:41.130 PM launchservicesd[81]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:41.152 PM appleeventsd[53]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:41.172 PM sharedfilelistd[311]: SecTaskLoadEntitlements failed error=22
7/9/19 3:17:41.172 PM TOCGenerator[1941]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.6 instead of 10.11.6. This is not a bug in Gestalt – it is a documented limitation. Use NSProcessInfo’s operatingSystemVersion property to get correct system version number.
Call location:
7/9/19 3:17:41.172 PM TOCGenerator[1941]: 0 CarbonCore 0x900e4e3d ___Gestalt_SystemVersion_block_invoke + 135
7/9/19 3:17:41.172 PM TOCGenerator[1941]: 1 libdispatch.dylib 0x9836983f _dispatch_client_callout + 50
7/9/19 3:17:41.172 PM TOCGenerator[1941]: 2 libdispatch.dylib 0x9836971b dispatch_once_f + 78
ilja
July 10, 2019, 5:41am
#7
This does not look like a GarageSale crash log. Rather, it seems some kind of global system log. I does not contain any information related to GarageSale at all.
Hi gardengoddess1,
you should find the Crash log file in your User Library* here:
Macintosh HD/Users/yourUserName/Library/Logs/DiagnosticReports/
Can you send us the latest GarageSale crash report? Its name should start with “GarageSale_2019-07…”
Please compress (zip) the file before sending it to us. You can send it to our support email, too:
garagesale@iwascoding.com
* Please note: The user Library is hidden by default! Click the Finder's Go menu and press the option key (alt) to make the user Library show up in the
menu. Selecting it will open it in the Finder.
ilja
Closed
July 20, 2019, 6:59am
#9
