The first beta version of GarageSale 7.0.5 is available for you to download and test from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.5b1.zip
If you reported or were effected by any of the issues listed below, please give this version a try and see if the issue is resolved.
What’s new in GarageSale 7.0.5
- dragging and dropping images from the Photos app on macOS 10.12 Sierra works again
- Orders section: added menu command to show shipping address in Maps app
- Listing section: added image context menu command to import images directly from Camera
- fixed possible crash when items referenced by smart groups where no longer present in the database
- pressing the return key in “Edit Image URL” panel now closes the panel instead of inserting newline character into URL
- right clicking on placeholder image in listing preview now shows a context menu containing the “Add URL Image” command
- fixed a possible crash when computing variation quantities during auto-relist of a variation listing
- fixed a possible crash when opening the “Advanced” tab in the listings inspector
- initial switch to the “Advanced” tab should be much quicker now
- eBay messages created in GarageSale should now be send quicker if GarageSale is busy downloading other eBay data
- fixed a problem where a listing’s state wasn’t properly updated when eBay listing data was received
- added additional safeguards against too many listing being started during auto-relist
