GarageSale 7.0.6 Beta 1 Released
GarageSale 7.0.6 Beta 1 is available for you to download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.6b1.dmg
What’s new in GarageSale 7.0.6
  • built-in image editor can be zoomed and scrolled
  • various crash fixes
Uhm… do I have to move GS icon into application folder? It’s different from previous versions …
If you are running macOS Sierra, you have to drag it to the Applications folder. Otherwise, Apple’s “App Translocation” feature is not disabled and the auto-updater won’t work once updates arrive.
If you are on earlier system version, you can drag it anywhere you want to. Please avoid running it directly from the mounted disk image.
