GarageSale 7.0.6 Beta 3 Released
GarageSale 7.0.6 Beta 3 is available for you to download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.6b3.dmg
What’s new in this Beta version
  • double-click to open image editor now works with all listing images in all layouts and Preview header
  • in the attributes panel, GarageSale will download 6000 suggestions per attribute instead of 50
  • ‘Live’-inspector in listing section summarizes current bid, bid count and views when multiple listings are selected
What’s new in GarageSale 7.0.6
  • built-in image editor can be zoomed and scrolled
  • on startup, GarageSale selects the items that were last selected
  • double-clicking an image in preview mode will now open the built-in editor
  • added smart group rules for ‘auto restart’ and ‘did use auto-restart’
  • clicking the ’paid’ checkbox for orders or transactions is now reflected on eBay
  • shows warning when ‘paid’ or ‘shipped’ checkbox changes cannot be uploaded to eBay because there’s no internet connection
  • Best offer: auto accept and auto decline field can contain the same value without raising an error
  • image context menu in inventory section works again
  • when uploading listings, url-based images sourced from linked inventory items are handled correctly
  • source list select and shows newly created items again
  • Image Editor: filters are no longer applied to crop mask
  • various crash fixes
@ilja What is this feature exactly?
Now it works also for my template, thanks!!
It allows you to add ‘Item specifics’ to your listing. These can improve the chances of your listing appearing when someone does an advanced search on eBay.
Fine, thank you for clarification
