The first beta release of GarageSale 7.0.8 is available for you to download from the URL below:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.8b1.dmg
What’s new in GarageSale 7.0.8
- the image context menu in editor mode now shows the image’s dimensions
- updated ‘Icon Legend’ in the Help menu
- added support for a different flavour of eBay TurboLister CSV files
- remembers the time interval you last selected in the built-in scheduler and uses it for new events
- will display a local error when user enabled eBay’s ‘Global Shipping Program’, but lists in a category where GSP is not supported
- addresses a crash during outline view manipulation (e.g. duplication or re-listing) under low memory conditions
- fixed crash when trying to end a listing, for which GarageSale does not have account information
- fixed an issue when verifying your PayPal API signature
- fixed an issue where the ‘Download images’ flag in the ‘My eBay Import’ panel was ignored
- fixed a problem which caused not all charity organisations supported by eBay to appear
