The third beta version of GarageSale 7.0.9 is available for you to download from the URL below, or from the built-in updater if you are running a previous beta version:
https://downloads.iwascoding.com/downloads/GarageSale_7.0.9b3.dmg
What’s new in since the last beta release
- fixed a problem with selection changes after smart group updates
What’s new in GarageSale 7.0.9
- performance improvements when selecting or duplicating large number of listings
- ‘New’ menu in the main menubar now matches the ‘New’ popup menu in the main window’s toolbar
- the menu item for creating scheduler events from listing now a has account submenu like the ‘Start listing’ command when you have more than one eBay account authorised in GarageSale
- added ‘Cancel’ button to ‘Wait on Quit’ panel
- fixed a problem where changes to various amount fields weren’t correctly reflected in smart groups
- instead of uploading them again, GarageSale now re-uses images that were uploaded to a custom image server before its configuration was changed to use the HTTPS protocol for image download
- fixed resizing quirks in the scheduler window
- various crash fixes
