GarageSale 7.0 Beta 49 Released
Beta 49 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b49.zip
  • fixed computation of ‘total’ amount for multi-item orders
  • when creating new eBay listings, the date for eBay scheduler defaults to current date
  • built-in update works when GarageSale is running on macOS Sierra
  • fixed several crashes
What’s new in GarageSale 7
  • can import listing drafts from the GarageSale Scout app on iPhone
  • a new custom database engine, which deals better with large amounts of data and allows us to adapt to eBay changes more quickly
  • can automatically generate SKU for your variations
  • added a “Reveal Original” command to the outline view context menu when a smart group item is selected. Using that command, you can easily jump to the original item of an item shown in the smart group, for instance to delete it or move it to a different folder
  • return policy, payment options, and tax settings can be specified in GarageSale’s XML import format
  • added support for specifying shipping insurance cost on eBay Italy and France
  • added 4 new designs
  • when in Listing Editor mode, there’s now basic syntax highlighting and auto-completion for tags when in HTML or Markdown mode
  • much more
Upgrades and Pricing
Migrating from GarageSale 6
  2. Quit GarageSale 7
  4. Restart GarageSale 7
What’s still missing
@ilja every damned time I instal a new version… it opens on his own with all selected :cold_sweat: …
You should talk to the AppCleaner guys.
