Beta 50 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b50.zip
- brings back Delicious Library importer
- fixed some quirks when creating new scheduler events using the plus button in the lower right corner of the scheduler window
- updated GarageSale Help
- tries to keep an item selected, when it is moved to a different smart group in response to a user action (e.g. paid checkbox in orders section was clicked)
- shows a placeholder image in Listing Editor mode, if an image cannot be found
What’s new in GarageSale 7
- a new custom database engine, which deals better with large amounts of data and allows us to adapt to eBay changes more quickly
- added support for specifying shipping insurance cost on eBay Italy and France
- added 4 new designs
- when in Listing Editor mode, there’s now basic syntax highlighting and auto-completion for tags when in HTML or Markdown mode
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
