the final version of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier version):
https://downloads.iwascoding.com/downloads/GarageSale_7.0.zip
Thanks to everybody who invested his or her time in testing the alpha and beta releases. GarageSale 7 wouldn’t have been possible without you!
- performance improvements when working in Inventory section
- changing the ‘Shipped’ flag in the Orders section will update your order on eBay, even when no tracking number is present
What’s new in GarageSale 7
- a new custom database engine, which deals better with large amounts of data and allows us to adapt to eBay changes more quickly
- added support for specifying shipping insurance cost on eBay Italy and France
- added 4 new designs
- when in Listing Editor mode, there’s now basic syntax highlighting and auto-completion for tags when in HTML or Markdown mode
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
