Beta 12 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b12.zip
- users can control-click overview tables to customize visible columns
- when importing your GarageSale 6 library, auctions are now put into a separate group in the hierarchy instead next to the listing they were started from (see below for instructions on how to re-import your library)
- fixed several bugs in the GarageSale 6 importer, that caused listing statuses, and thus smart group contents, to differ in GarageSale 7 (see below for instructions on how to re-import your library)
- resolved an performance issue when selecting groups or smart groups with a lot of items (as an unfortunate side effect, the image overview mode is only available on OS X 10.11 or later - see this post for a detailed explanation)
- new listings can be imported from XML files (format stays the same as in GarageSale 6)
- new inventory items can be imported from CSV files (format stays the same as in GarageSale 6 - except for an added ‘barcode’ column)
- no longer scrolls to the Trash when deleting an item via keyboard shortcut
- added SKU column to listing overview table
- fixed tooltips for the listing mode switch in the main window’s toolbar
- fixed several UI glitches in the attributes panel
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Export any listing you created in GarageSale 7
- Quit GarageSale 7
- Restart GarageSale (make sure you using beta 8)
- Import any listings you imported in step #1
What’s still missing
- a user manual
