Beta 14 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b14.zip
- you can have an already started listing selected from the search result when starting a new listing
- the main window shows up for users still running OS X 10.10
- an alert is displayed when you try to use an already started listing in the scheduler
- when importing your GarageSale 6 library, inventory images are correctly shown in listings linked to them (*)(thanks @bossbreak)
- group content in the inventory section can be sorted
- new scheduler events can be created from a listing’s context menu
- the media browser doesn’t stay empty when you have the Photos application open
- the listings table in the scheduler window is updated when dragging a listing onto an existing event
- dropping listings on the events table in the scheduler window
- when using a custom image server, setting the image upload size to “Use Original Size” no longer crashes GarageSale’s preview (thanks @icspanta)
- listing SKUs are submitted to eBay
- when a GarageSale 6 library is present on first start, there is now an option to skip the importing of this library
- added a “not refunded” rule to the default smart groups in orders mode (*)(thanks @Brian)
- setting image upload size to ‘Use Original Size’ no longer crashes GarageSale’s preview
- changing the color of design properties doesn’t effect earlier edited design properties (thanks @Brian)
- ‘Buyer Requirements’ settings can be edited if already set before (thanks @Brian)
- added a ‘barcode’ tag to the XML import file format for listings
- includes workaround for several crashes reported through GarageSale’s crash reporter
(*) this change requires a re-import of your GarageSale 6 database. Please see below for instructions.
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Export any listing you created in GarageSale 7
- Quit GarageSale 7
- Restart GarageSale (make sure you using beta 8)
- Import any listings you imported in step #1
What’s still missing
- a user manual
