Beta 16 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b16.zip
- grid and table overviews now have a context menus
- items from grid or table overviews can be dragged into the outline view
- messages can be sorted by state (read vs. unread)
- ‘Launch Control’ and ‘Preflight’ windows are now resizable
- when revising selected listing fields only, the ‘quantity’ field is no longer revised alongside
- fixed missing images after import from GarageSale 6 (Mac App Store version only) (*)
- listings can be re-listed without changes, even when the local listing contains errors
- table overview in Orders, Inventory, and Reports section now allows multiple selection
- when revising an active listing’s price, the change is immediately visible in ‘Live’ inspector
- GarageSale is more resilient against corrupt database records
(*) this change requires a re-import of your GarageSale 6 database. Please see below for instructions.
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Export any listing you created in GarageSale 7
- Quit GarageSale 7
- Restart GarageSale
- Import any listings you imported in step #1
What’s still missing
- a user manual
