Beta 21 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b21.zip
- GarageSale deletes expired images it previously uploaded to your FTP and WebDAV servers
- reduced memory usage
- better performance when duplicating or importing items
- fixed several crashes when invoking the “Undo” command after a listing change
- improved AppleScript support
- ‘Paste Listing components’ command works again
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- a user manual
