Beta 27 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b27.zip
- scheduler events can be enabled without verification
- can duplicate (and optionally move originals to the trash) when creating scheduler events from already started listings
- faster loading of scheduler window and activation of events
- you can search for listing number in listings mode (for best performance, make sure to only search in the listing number field in the search menu)
- improved bundled “ProDesigns”: better mobile support for hover galleries, removed checkbox tag so listings no longer get rejected by eBay.de
- fixed a problem with the “list as classified” checkbox
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- a user manual
