a Beta 3 version of GarageSale 7 is available for you to download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_7.0b3.zip
- fixed a bug where the barcode field in the variations panel would not remember its value, unless another text field was clicked before a different variation was selected
What’s new in GarageSale 7
- support for barcodes for on the variation level
- much more
Upgrades and Pricing
Migrating from GarageSale 6
Where does GarageSale 7 store it’s data
~/Library/Containers/com.iwascoding.garagesale7/Data/Library/Application Support/GarageSale
You can go to this folder by choosing “Show Library Folder” from the “Help” menu.
What’s still missing
- a user manual
