Beta 36 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b36.zip
- added support for item attributes that allow multiple values and offer suggestions from eBay. A table view with combo boxes is shown in these cases, e.g. for the ‘Style’ attribute in the Music > Records category
- re-listed listings are shown immediately in the outline view after the re-list command finished. Previously you had to switch to a different section, e.g. orders, and switch back to listings to make them visible
- added a “Ignore Future warnings like this” command to the context menu (right-click) for warnings returned by eBay during listing verification. After using it, GarageSale will not show the ignored warning the next time it is returned by eBay
- the “New Scheduler Event” command from the ‘+’ button in the toolbar now correctly determines the selected listings. Previously it would always use the selection from the outline view, even if the overview (middle section of the window) was the active view (blue selection highlight)
- when duplicating previously started listing when creating an event or starting listings, the order of the original selection is preserved
- fixed a bug where variation images weren’t deleted from a listing when the respective variation was deleted
- fixed a crash when trying to start a listing that was already started
- improved user interface when leaving feedback for multiple transactions in the Feedback panel
- added an “Select All” command to the context menu in the overview (right-click)
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- a user manual
