GarageSale 7 Beta 37 Released
Beta 37 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b37.zip
  • fixed a bug introduced in Beta 36 that caused missing listing designs
What’s new in GarageSale 7
  • can import listing drafts from the GarageSale Scout app on iPhone
  • can automatically generate SKU for your variations
  • added a “Reveal Original” command to the outline view context menu when a smart group item is selected. Using that command, you can easily jump to the original item of an item shown in the smart group, for instance to delete it or move it to a different folder
  • return policy, payment options, and tax settings can be specified in GarageSale’s XML import format
  • much more
Upgrades and Pricing
Migrating from GarageSale 6
  2. Quit GarageSale 7
  4. Restart GarageSale 7
What’s still missing
  • localized user interface for languages other than English
  • a user manual
I think that the Verify listing menu item is still not working. It seems to work for the first listing I try to verify. But for each subsequent listing, it gives me the results of the first (including the listing’s title). Is this just me or can you reproduce this behaviour?
Thanks for reporting. We’ll look into this.
I’m getting the spinning ball more and more. Am I the only one having this issue?
I’m ready to throw my computer through the window.
Please help before I break something expensive.
I agree with @Fonky1, the spinning wheel is a serious issue.
It’s the sole reason I’m still stuck on GarageSale 7, Beta 17.
Beta 17 has its issues but it doesn’t have the spinning ball/wheel issue that later versions have.
Hopefully the GarageSale guys are heavily working on this issue.
It’s probably the only reason we still at Betas instead of Release 1. @ilja
Thank you.
Not necessarily a bug, but I find it a little odd that if you delete an event that still has a listing on it the listing still shows on the chart until you erase the deleted events.
I just tried to use Beta 37. I found a few things right away that are keeping me from switching over to GarageSale 7. In the few minutes I tried to use it, this is what I found:
  1. The Private Comments were not brought over from GarageSale 6.
  2. The listings I created last week (the templates that were used to create new Ebay postings) were not brought over.
  3. When I checked off an order as having been shipped, this was not communicated to eBay. They still show up on the “Awaiting shippment” page.
One more thing.
When sending an email to a buyer to notify them that I shipped their orders, I had to check the box to send me a copy each time. Is there a way to make that “stick” or make it the default?
Also, the emails haven’t arrived in my Inbox yet, so I am not sure they got to my customers either.
Hello,
you should order the results after a research alphabetically.
And I’m french so we use letters like “é” or “à”. In GaraSale 6, I can make a search with for example the word megane or mégane and I have the same result. In garagesale 7, it’s completly diffrent.
regards
Just curious if you have you done a re-import of your GS6 library with Beta 37?
Have you checked if your eBay accounts were correctly imported from GarageSale 6? Do you appear in GS 7 under Preferences > Accounts.
I’ll add a ticket to make that box value sticky.
Maybe we can setup a screen sharing session via Skype or the Messages app, so I can take a look at the issue “with my own eyes” ?
Could explain how it is different? Is the ordering different, or are you getting entirely different results?
Hello,
in GS6, if I write “megane” or “mégane” I have the same result
in GS7, if I write “megane” I only have the result with “megane” and the auctions with “mégane” doesn’t appear.
And the other point really important for me, is the result of a research, it would be better if the order was done alphabetically.
