Beta 38 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b38.zip
- added support for specifying shipping insurance cost on eBay Italy and France (sorry, these are the only sites eBay still offers shipping insurance for)
- GarageSale would download order data even though you told it not to do so in the Preferences by setting the popup to ‘Never’. This has been corrected. (If you have a lot of running listings, and you are experiencing frequent hanging while working in GarageSale, this option might ease the situation.)
- thumbnail overview shows price for listings not yet started. Previously no price at all was shown for these listing
- adjusted indicator color in thumbnail overview to match colors in outline view
- for listings that ended without a bid, thumbnail overview shows the contents of the starting bid field (Previously the thumbnail overview was showing the bid at the last auction start, which could be confusing)
- thumbnail overview shows the price range for variation listings
- tax settings are correctly imported from listings exported with GarageSale 6
- the “Import Inventory Items” menu command in File menu now works as expected (previously it was interpreting the CSV file as a listing, instead of an inventory item)
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- a user manual
