Beta 39 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b39.zip
- the ‘Verify Listings’ command in the Listing’s section toolbar now shows a Preflight window, that stays connected to your current selection. For a Preflight window that follows your currently selected items, invoke the ‘Show Preflight Window’ command from the ‘Window’ menu
- when you import existing listings with ‘Import from My eBay’ command, these listings will get selected in the outline view when importing is done
- the list of eBay messages in the ‘Accounts’ window now automatically updates when new messages arrive. Previously you had to change the selected account to get an up-to-date list of messages.
- when you closed certain popover windows (e.g. ‘Shipping’, ‘Category’, ‘Product’ or ‘Attributes’ settings) by clicking outside the popover in a way that changed the selected listings, the settings you changed in the popover could have been changed in the newly selected listings, instead of the ones that were selected when opening the popover. This has been corrected.
- the search field now correctly handles diacritic characters frequently used in some languages (é, ø, ü). However, this change is only effective for fields that have been modified in Beta 39 or later. If you upgraded from GarageSale 6, re-importing your library will apply this change to your complete library.
What’s new in GarageSale 7
- added support for specifying shipping insurance cost on eBay Italy and France
- much more
Upgrades and Pricing
Migrating from GarageSale 6
- Quit GarageSale 7
- Restart GarageSale 7
What’s still missing
- a user manual
