Beta 6 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b6.zip
- fixed several rotation related issues with photos taken on iPhones
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
Where does GarageSale 7 store it’s data
~/Library/Containers/com.iwascoding.garagesale7/Data/Library/Application Support/GarageSale
You can go to this folder by choosing “Show Library Folder” from the “Help” menu.
What’s still missing
- a user manual
