Beta 7 of GarageSale 7 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b7.zip
- fixed another round of rotation related issues with photos taken on iPhones (if you are still seeing wrongly rotated thumbnails or images in the preview, you need to delete the image from your listing and re-add it once again)
- double-clicking an inventory item in the overview table works
- searching for inventory product works
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
Where does GarageSale 7 store it’s data
~/Library/Containers/com.iwascoding.garagesale7/Data/Library/Application Support/GarageSale
You can go to this folder by choosing “Show Library Folder” from the “Help” menu.
What’s still missing
- a user manual
