Beta 7 of GarageSale 8 is available for you to download from this URL (or by using the built-in updater if you are already running an earlier beta version GS 7):
https://downloads.iwascoding.com/downloads/GarageSale_7.0b8.zip
This release fixes issues in the component that handles converting your GarageSale 6 library into the new library format used by GarageSale 7. This is what we fixed:
- description of inventory items is correctly imported (thanks @Matthew_Olson)
- smart groups are no longer imported into the listing section, when their rules can no longer be evaluated in GarageSale 7 (this is because the order tracking functionality has moved to Orders section in GS 7)
If you need to re-run the initial import phase, because you need your inventory item description, or you don’t want to delete the non-functional smart groups manually, this is how to do it:
- Export any listing you created in GarageSale 7
- Quit GarageSale 7
- Restart GarageSale (make sure you using beta 8)
- Import any listings you imported in step #1
What’s new in GarageSale 7
- much more
Upgrades and Pricing
Migrating from GarageSale 6
Where does GarageSale 7 store it’s data
~/Library/Containers/com.iwascoding.garagesale7/Data/Library/Application Support/GarageSale
You can go to this folder by choosing “Show Library Folder” from the “Help” menu.
What’s still missing
- a user manual
