GarageSale 8.0.11 out and can be downloaded from the link below or the built-in updater:
https://downloads.iwascoding.com/downloads/GarageSale_8.0.11.dmg
What’s new since the last beta
- deleting item attributes when multiple listings are selected works again
What’s new in GarageSale 8.0.11
- fixed a bug in the attributes panel, where changing an attribute’s value might alter an unrelated attribute
- reduced temporary memory usage when exporting a larger number of listings
- fixed performance issue when eBay messages where unnecessarily sorted when the messages view was not on-screen
- Synching: improved auto-retry in case of connection losses
Thanks for using GarageSale!
