the third beta version of GarageSale 8.0.4 is out and can be downloaded from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.0.4b3.dmg
- Synching: fixed a bug where hierarchy conflicts (e.g a listing was moved to different folders on two different Macs at the same time) weren’t correctly handled (if you been effected, you need to restart synching from scratch - cc @fedege96)
What’s else is new GarageSale 8.0.4
- fixes an issue where GarageSale 8 did not show its main window right after the import of a GarageSale 7 database
- PayPal fees are now correctly included in Income Reports
- fixed a possible crash when opening the eBay Preferences
- fixed a possible crash when updating order data
- fixed a possible crash when opening the Sync Conflict panel
- fixed a possible crash when opening the context menu for an image
- fixed a possible crash when displaying an eBay order
Thanks for using GarageSale!
