@ilja the price looks like quite strange to me, don’t you think? Why so many numbers? Isn’t it the reason? Please le me know, this issue is very serious for me.
That’s how totally normal. This is how floating point numbers are stored in memory. Also, this file is written by Apple code in plist xml format, so you can rest assured that this code is well tested.
Also, please don’t post your customer private data on our public forum.
Ouch! Posted mistakenly the uncensored photo! I did’t noticed that it also contained those data.
If this behavior is normal, not much to say, I will cross finger and contact them… please, if you have any news from GT developers, let me know about, I am totally stuck here…
Thanks Ilja.
I ran the update, and now I cannot revise my listings because “there’s no account token.” I tried refreshing my token, which appeared to work, but I get the same error when I try to revise an item. I also cannot download my listings from eBay. How do I fix this?
If you remove your eBay account from the GarageSale preferences > Accounts, restart your Mac and then re-add your eBay account, does this fix the issue for you?
