The second beta version of GarageSale 8.0.6 is out and can be downloaded from this link
https://downloads.iwascoding.com/downloads/GarageSale_8.0.6b2.dmg
What’s new in GarageSale 8.0.6
- after invoking the ‘Duplicate’ command on a listing in the outline view, the outline view should retain the keyboard focus
- Synching: addresses an issue, where a conflict triggered by deleting an item locally, while moving the same item to a different group on another Mac at the same, was not correctly handled
- Synching: holding down the Option/Alt key while choosing a conflict resolution (local or remote) in the Conflict panel, applies that resolution to all conflicts
- Synching: improved performance when opening Conflict panel
- Synching: fixed possible crash when importing received data from sync server
Thanks for using GarageSale!
