GarageSale 8.0.6 is out and can be downloaded from the link below or the built-in updater:
https://downloads.iwascoding.com/downloads/GarageSale_8.0.6.dmg
What’s new in GarageSale 8.0.6
- worked around an issue that prevented GarageSale users from completing eBay’s third party client authorization process
- after invoking the ‘Duplicate’ command on a listing in the outline view, the outline view should retain the keyboard focus
- fixed a crash when malformed data from eBay was received while downloading attribute suggestions
- Synching: addresses an issue, where a conflict triggered by deleting an item locally, while moving the same item to a different group on another Mac at the same, was not correctly handled
- Synching: holding down the Option/Alt key while choosing a conflict resolution (local or remote) in the Conflict panel, applies that resolution to all conflicts
- Synching: improved performance when opening Conflict panel
- Synching: fixed possible crash when importing received data from sync server
Thanks for using GarageSale!
