GarageSale 8 Beta 57 is out and can be downloaded via the built-in updater or from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.0b57.dmg
- fixed an issue that could cause smart groups using the ‘days remaining’ rule to show incorrect results when GTC listings where auto-renewed by eBay
- shows alert when trying to enable synching when the library contains images that are too big to be synched
What’s new in GarageSale 8
- bulk “search and replace”
- Improved AppleScript
- Smart Groups can be sorted
- filter by auction/BIN
Synching
