GarageSale 8 Beta 61 is out and can be downloaded via the built-in updater or from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.0b61.dmg
- always sends ‘Returns Not Accepted’ flag to eBay when ‘Returns Accepted’ checkbox is not clicked. Not doing so caused listing to appear as ‘Returns Accepted’ on eBay on some eBay sites
- fixed a possible crash in when opening the Account window
- Synching: GarageSale Pro account details stay present after initial downloading of data
What’s new in GarageSale 8
- bulk “search and replace”
- Improved AppleScript
- Smart Groups can be sorted
- filter by auction/BIN
- GarageSale is correctly signed for MacOS 10.15 Catalina
Synching
