GarageSale 8 Beta 62 is out and can be downloaded via the built-in updater or from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.0b62.dmg
- fixed a crash when updating orders
- auto-updater works correctly under MacOS 10.15 Catalina (when next beta version is released)
What’s new in GarageSale 8
- bulk “search and replace”
- Improved AppleScript
- Smart Groups can be sorted
- filter by auction/BIN
- GarageSale is correctly signed for MacOS 10.15 Catalina
- always sends ‘Returns Not Accepted’ flag to eBay when ‘Returns Accepted’ checkbox is not clicked. Not doing so caused listing to appear as ‘Returns Accepted’ on eBay on some eBay sites
Synching
