GarageSale 8 Beta 63 is out and can be downloaded via the built-in updater or from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.0b63.dmg
- fixed a bug in the “Rotate Image” commands, that caused rotated images to grow in size, thus making subsequent rotations much slower than it should be
 - more user interface elements should now show the correct localised labels on non-English systems
What’s new in GarageSale 8
 - bulk “search and replace”
 - Improved AppleScript
 - Smart Groups can be sorted
- filter by auction/BIN
 - GarageSale is correctly signed for MacOS 10.15 Catalina
 - always sends ‘Returns Not Accepted’ flag to eBay when ‘Returns Accepted’ checkbox is not clicked. Not doing so caused listing to appear as ‘Returns Accepted’ on eBay on some eBay sites
Synching
