GarageSale 8 Beta 64 is out and can be downloaded via the built-in updater or from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.0b64.dmg
- improved German localization
- Synching: fixed a problem which could leave the database in an unsynchable state after a listing was manually deleted on two Macs around the same time
What’s new in GarageSale 8
- bulk “search and replace”
- Improved AppleScript
- Smart Groups can be sorted
- filter by auction/BIN
- GarageSale is correctly signed for MacOS 10.15 Catalina
- always sends ‘Returns Not Accepted’ flag to eBay when ‘Returns Accepted’ checkbox is not clicked. Not doing so caused listing to appear as ‘Returns Accepted’ on eBay on some eBay sites
Synching
