Revise panel allows for revision of VAT details only (important for German users, as the VAT rate has changed on July, 1st)
the “check your quantity” warning is shown only shown in the Launch Control window, when the “Use remaining quantity” box is not checked
fixed a crash in the Image Resize window
Synching: increased the time-out for the connection when saving the server persists incoming data, the prevent dropped connections for very large changes
This update seems to have corrected the quantity issues when relisting. I will report again after a few cycles of auto cancel and relist run to see if the issues with quantity are repaired.
@ilja Reporting on the auto cancel feature. The latest Beta 4 has repaired the quantity issues that I was having.
An old problem has surfaced again. I use bulk edit to add all my listings to the auto cancel Smart folder so I can monitor them for running the feature. However it also grabs all my AUCTIONS which I don’t want to cancel 1 hour before the listing ends. There should be a way to exclude auctions from the auto cancel feature since there is no reason I can see to end and relist auctions.
