the Launch Control window now offers "Use Remaining Quantity" option to specify your remaining quantity as new quantity when revising or re-listing
Remove design HTML during “Import from My eBay”
Advanced settings for “Import from my eBay”
Added ‘Global Status’ smart group property
Update listings based on SKU during XML (and CSV) import
the category chooser panel now shows the category id of the selected category
added a “Hide Ended Listings” option to the view settings for the My eBay import panel
added “Uses Variations” smart group rule
added an additional menu command for printing packaging slips
fixed cosmetic issues with the search field width in certain toolbars
when revising a listing’s quantity on eBay, a warning is displayed if the new quantity exceeds the current quantity left
when using the new “Update existing listings” option during CSV or XML import, GarageSale can open the Revise panel for updated, running listings after the import is done
improved startup performance, especially when a lot of listings where selected when GarageSale was last quit
Preview: Character count in title field (listing design) now gets shrunk while typing
improved performance when updating list of warnings and errors in Launch Control window, especially when it's processing a lot listings
the “Take Photo” from iPhone command in the context menu of the Preview now works as expected
Launch Control Window: ‘Use Multiple Connections’ option stays enabled after starting a single listing only
preview is no longer updated after every keystroke in the SKU field to reduce CPU load
you can now search for listing titles and SKUs of sold in the Orders section
users can search for SKUs of ordered items in the Orders section
a secondary eBay category can be removed with a Revise operation from a running listing on eBay (if still allowed for that listing by eBay)
added “Listings” and "SKU" columns to overview table in the Orders section
fixed issues with detached Attributes popover not correctly updating when switching to another listing
Synching: disabled synchronization of smart groups in Orders section
