the final version of GarageSale 8.2.1 is available for you to download from the link below or the built-in updater:
https://downloads.iwascoding.com/downloads/GarageSale_8.2.1.dmg
What’s new in GarageSale 8.2.1
- fixed a bug that caused duplicate category entries to appear in the category browser
- added ‘Hide Results From Trash’ command to search field menu
- smart groups with the ‘Feedback Received’ rule updated immediately when new status is received from eBay
- the legacy media browser can access Photos library again
- exported listing files can be dragged directly into the listings outline view
- added [[item.projectedEndDate]] macro command to include the anticipated end date in your listing’s description. This command anticipates your auto-cancel settings and might let your watchers know that you are planning to end a GTC listing early
- changes to the quantity field in the inspector are immediately reflected in other parts of the application
The GarageSale team
