ilja
September 18, 2020, 3:33pm
#1
the first beta version of GarageSale 8.2 is available for you to download and test from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.2b1.dmg
We made many code changes since the previous beta release, so we decided to rename the current 8.1.2 Beta series to GarageSale 8.2.
What’s new in Beta 8.2
improved performance when selecting (smart) groups with a large number of listings
improved performance when evaluating smart groups with large number of listings
improved performance when loading search results
fixed a crash when moving an item to the trash that had an invalid link to its parent group
Other changes contained in this release carried over from the 8.1.2 Beta series
fixed bug that could prevent a single order from appearing in a Report
Car Parts: multiple found vehicles can be selected by holding the shift key, and added to a listing by double-clicking
Car Parts: compatible vehicles can be deleted from a listing
Smart Group editor: the property popup in the will be sorted by alphabet, when the option key is held down when the Smart Group editor is opened
performance improvements when using a large number of listings with the Auto-Cancel option
when generating a label with Endicia, the shipping carrier for the selected order is set to “USPS”
The GarageSale team
7415 listings selected in 1 second. OUTSTANDING!
ilja
September 18, 2020, 8:12pm
#3
Great to hear! Can you measure how long it took in the GarageSale version you were running before?
I was measuring the wrong thing. Right clicking 7400 listings in a smart group takes 34 seconds to get a dropdown menu in this version, 45 seconds in previous version. 866 listings in previous version takes 4.93 seconds to right click and about the same in this version. sorry about the mixup
This morning in smart groups, any selection of ALL freezes on the spinning ball. Any selection in normal folders of “ALL” works fine. Did GS break?
ilja
September 19, 2020, 1:23pm
#6
Could you please create a “Sample” of GarageSale with the Activity Viewer (‘View’ menu > 'Create Sample) when the beach ball is shown?
I am running OS 10.14.6. That menu item is not in the drop down. So I selected all in the smart group and it selected “ALL” in less than 1 second. Its been 1 hour since the problem. Maybe something was updating in the background and it was only appearing to be a freeze?
ilja
September 19, 2020, 2:11pm
#8
Activity Viewer is a separate application that ships with your Mac. It’s under Application/Utilities.
Thanks for the update. If you get the beach ball again, maybe you can catch what’s causing it with a “Sample”.
This dropdown? Sample process?
ilja
September 19, 2020, 3:25pm
#10
Yes, but you need to select GarageSale in the window first. You can use the search field to filter for „Garage“.
Got it. Just learned something new.
Selected 21,000 items (right hand pane) in 6 seconds. Wow.
ilja
Closed
October 1, 2020, 3:46am
#13
