GarageSale 8.3.4
GarageSale 8.3.4 is available for you to download from the link below or via the built-in updater:
https://downloads.iwascoding.com/downloads/GarageSale_8.3.4.dmg
What’s new in GarageSale 8.3.4
  • the ‘item condition’ property can be removed from running listings on eBay with the Revise command in categories that don’t require conditions
  • worked around an error returned by eBay when submitting a tracking number
  • fixed problems with search field popup on older versions of macOS
  • Orders section: increased height of shipping address area to make room for longer addresses
  • fixed behavior of text snippet popup in Condition description popup
  • Listing section, Editor mode: images can be deleted by pressing command-delete shortcut
  • Synching: fixed an issue on macOS Big Sur that prevented deleting data on the server when re-enabling synching
  • cosmetic changes to improve looks on macOS Big Sur
The GarageSale team
Hi @ilja , is it somehow possible to increase also the image size into the order so the item can be easily recognizable from the photo? Now it is too small…
Also, when a listing is not in GS database and a new order is downloaded from eBay, GS does not show the photo because there is not a corresponding item in GS. Might GS download the sold item photo from eBay so the order image is not blank? That would help a lot.
Thank you
Federico
Hi there
thank you for the update
I want to update it, but unfortunately this message appear
Do you get that message when trying to update to GarageSale 8.3.4?
If so, could it be that you don’t have the GarageSale application installed on your Mac but still starting it from the installation “disk image” (.dmg)?
What you also can do is to just download the latest version from the GarageSale website straight ahead:
https://www.iwascoding.com/GarageSale/Downloads.html
Make sure that you actually install it on your Mac. Please see the help here:
https://manual.iwascoding.com/gs8/en/Installation_and_Setup-Installation.html
hi there, kristian thank you for your reply
I do have the application installed.
If I’m following your instruction, replacing the older app, does my data still there when I open the new one? sorry for the very basic questions.
Don’t worry, replacing the GarageSale application won’t touch your data.
The GarageSale database is stored in your User Library but not inside the application package.
thank you very much Kristian. good luck to GarageSale team.
