GarageSale 8.3.5 Beta 8 is available for you to download from the link below:
https://downloads.iwascoding.com/downloads/GarageSale_8.3.5b9.dmg
What’s new in Beta 9
- tweaked scrolling behavior when programmatically selecting items in the outline view
- more tweaks to colors used outline and table views
What’s new in GarageSale 8.3.5
- programmatically selected entries in the main window outline view are scrolled to the middle
- worked around an eBay error when leaving feedback
- the ‘Time Remaining’ column in the Listing overview table is updated periodically
- the Image Markup editor works again on MacOS Big Sur
- Attributes Panel: combo boxes don’t contain duplicate suggestions for certain attribute types
- added an “Open GarageSale Community” command to Help menu
- Synching: Fixed a bug that prevented a Mac from uploading data to the sync server, when a user created a new conflict by editing the local database while the Conflict resolution panel was already open
- improved performance (less beach balling) when determining what images to delete from a custom FTP or WebDav image server
- multiple images can be selected, dragged, and reordered in listing Editor mode
- the ‘Move Selected Items To’ command is available from the Overview context menu
- added “Zoom to Fit when Opening” preference for the Image Editor to GarageSale’s preferences; when disabled, the Image Editor will open at the last used zoom level
- fixed a crash when uploading listing with the “Move Originals Options” options enabled, while it was pointing to a non-existent folder
The GarageSale team
