GarageSale 8.3.5available for you to download from the link or through the built-in updater:
https://downloads.iwascoding.com/downloads/GarageSale_8.3.5.dmg
What’s new in GarageSale 8.3.5
- worked around an eBay error when leaving feedback
- MacOS Big Sur: fixed a glitch with text colors in the Main Window outline view
- MacOS Big Sur: the “Image Markup” editor works again
- Main Window outline view: programmatically selected entries are scrolled to the middle
- Listing overview table: the ‘Time Remaining’ column updated periodically
- Attributes Panel: combo boxes don’t contain duplicate suggestions for certain attribute types anymore
- Synching: Fixed a bug that prevented a Mac from uploading data to the sync server, when a user created a new conflict by editing the local database while the Conflict resolution panel was already open
- improved performance (less beach-balling) when determining what images to delete from a custom FTP or WebDav image server
- Listing Editor mode: multiple images can be selected, dragged, and reordered
- the ‘Move Selected Items To’ command is available from the Overview context menu, too
- added a “Zoom to Fit when Opening” preference setting for the Image Editor. When disabled, the Image Editor will open at the last used zoom level
- Launch Control Window: fixed a crash when uploading listing with the “Move Originals” options enabled, while it was pointing to a non-existent group
- added an “Open GarageSale Community” command to Help menu
The GarageSale team
