GarageSale 8.3.6 (1292) crash during relisting 9 items. Nothing unusual. Reopened and relisted 5 that had not listed. Worked fine.
macOS Big Sur Version 11.4 (20F71)
crash during relisting.txt.zip (35.0 KB)
Thanks for the crash report. Unfortunately, it does not give quite enough information what the root cause of the crash is.
Hi Neal
Sorry to hear you are having problems.
Mine(for the fist time in 2 years) is running perfectly since I re-created it from Ebay - but that is months of work.
I do not know what my DB problem was but it seems to have gone away - fingers crossed.
No bragging, just letting you know.
