GarageSale 8.3 Beta 2 is available for you to download from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.3b2.dmg
- Bulk Search & Replace panel: added an “Exact search” option for finding the exact search strings, including HTML tags. This option bypasses GarageSale’s search index and scans through the entire library using brute force, thus it’s a little slower than the regular search
What’s new in GarageSale 8.3
- runs natively on Macs with Apple Silicon chips
- minimum macOS is requirement is now raised to macOS 10.14 Mojave
- fixed a crash when updating incomplete local listings with data from eBay
The GarageSale team
