work around missing items in the Main window toolbar on macOS Big Sur
icons for listings in the Main window outline view should reflect listing state changes more quickly
Shipping options panel: package weight can always be edited when ‘calculated shipping’ is used for either domestic or international shipping
What’s new in GarageSale 8.3
runs natively on Macs with Apple Silicon chips
minimum macOS is requirement is now raised to macOS 10.14 Mojave
fixed a crash when updating incomplete local listings with data from eBay
text snippet macros are now supported in the Condition description
category popover shows category tree version in sprocket menu when option key is held down
Bulk Search & Replace panel: added an “Exact search” option for finding the exact search strings, including HTML tags. This option bypasses GarageSale’s search index and scans through the entire library using brute force, thus it’s a little slower than the regular search
@ilja Thanks for adding the shipping weight to the panel. It has been one of them things that always made me click 3 extra times to add the weight. I also concur with @Neal on the missing tool bar items. Perhaps while working on tool bar items a “relist” and “revise” button could be added? The drop down menu makes an extra step to the process of relisting and revising.
Sorry for this. Seems my late night “improvements” of the bug fix nullified parts of the bug fix. Beta 8 should cure the toolbar problems for good (famous last words).
