GarageSale 8.3 Beta 8 is available for you to download from this link:
https://downloads.iwascoding.com/downloads/GarageSale_8.3b8.dmg
- more toolbar bug fixing
What’s new in GarageSale 8.3
- runs natively on Macs with Apple Silicon chips
- minimum macOS is requirement is now raised to macOS 10.14 Mojave
- fixed a crash when updating incomplete local listings with data from eBay
- text snippet macros are now supported in the Condition description
- category popover shows category tree version in sprocket menu when option key is held down
- Bulk Search & Replace panel: added an “Exact search” option for finding the exact search strings, including HTML tags. This option bypasses GarageSale’s search index and scans through the entire library using brute force, thus it’s a little slower than the regular search
- icons for listings in the Main window outline view should reflect listing state changes more quickly
- Shipping options panel: package weight can always be edited when ‘calculated shipping’ is used for either domestic or international shipping
The GarageSale team
