a new alpha release (a very early development release for preview) of the the upcoming GarageSale 8.4 is available for you from this address:
https://downloads.iwascoding.com/downloads/GarageSale_8.4a10.dmg
What’s new in this pre-release
- brings back control over Payment profiles when your eBay account is on Managed Payments. Turns out you still need to provider payment profiles, even with managed payments.
- Condition description can be removed from a listing with the Revise command
What’s new in GarageSale 8.4
- GarageSale no longer prompts for choosing a payment method if “Managed Payments” is activated for your eBay account (requires OAuth token, see above)
- If you are using profiles for shipping or returns, GarageSale will no longer prompt you to select a Payment profile (requires OAuth token, see above)
- Order section: New context menu entries in the order outline view to change order state (e.g. “shipped”) for selected orders
- GarageSale will prevent you from starting auction-style listings, when the auto-cancel feature is enabled
- Attributes window: enabled ‘autocompletes’ option for certain attributes (e.g. ‘Artist’ attribute in LP/Records section)
- Synching: re-worked conflict algorithm to reduce the number of times the Conflict window appears
- added AppleScript command to manipulate shipping weights
- various crash fixes
- text entered in the “user properties” area of the inspector is now searchable
- new smart group rule for searching “user properties” content
- GarageSale generates a ‘mobile summary’ from the first 800 characters of your listing description when uploading listings, which does not include GarageSale’s version identifier string
- the ‘Reveal Original’ command is available from the overview context menu (middle area) in the listing section
- the number of images used in a listing is shown in Editor mode
- added new Preferences settings (under eBay > Advanced) that prevents automatic switching to ‘Live’ view when listings are started
The GarageSale team
